One more FR from me, closely related to the previous one (cyclic symmetry). Currently, the Section View tool works very well in postprocessing but it could be further improved by making the contour plot legend adapt to it. What I mean is that the legend doesn’t change to show only values on the visible part of the model and remove the ones from the other side of the cut.
Here’s an example. The way the cyclic symmetry is defined (described in my previous FR) may cause such distortions in stress plots:
It would be great to be able to hide them. Since currently individual elements can’t be hidden (this was discussed before), the Section View cut is the best tool to hide these spurious concentrations and read correct stress values from the middle of the twisted shaft. However, you can see that the legend remains unchanged upon the cut and the inside of the shaft is completely colored in blue:
It’s possible to manually change the legend limits and to probe the correct values in the middle of the shaft using the Query tool but it would be nice to have such automatic cut-off for section views as well. However, it could be difficult to implement it so it’s just a loose suggestion in case it turns out to be relatively easy to add after all.
