Results Fields Temporarily Inaccessible
In version 2.2.9 it seems that as soon as an analysis is concluded, the Output, -Variables, -Type and -Factor are inaccessible (greyed out) along with the -Step Increments.
The only way to activate them is to press the Animation Play button. As soon as PPM displays the animation, all the fields are activated.
Is anyone else experiencing this anomaly ?
Yes, I had experienced this problem either.
That could be possible if you downloaded PrePoMax v2.2.9 within 10 minutes from when it was uploaded. I accidentally uploaded the wrong version initially, but I fixed it later. Can you try downloading the same version again?
Thanks @Matej
No issues with the latest download.
I will close the topic since the problem is solved.
