Getting this error while loading results in prepomax. I’m using prepomax as the pre/post postprocessing for the calculix solver. I’m sometimes facing issues as the model is hidden and I’m not able to see the model. And this issue is persisting most of the times when I click on the results. Please help me to resolve this.
Which version of PrePoMax are you using ? Can you try with the newest one available (2.1.4 dev) ?
Is there anything special in your models ? Some CalculiX features that may not be supported by PrePoMax yet such as beams ?
I tried downloading the latest version. And this is the Warning I’m getting
07/31/24 16:55:02 Warning: The opened file is from an incompatible version: PrePoMax v2.0.0
07/31/24 16:55:02 Some items might not be loaded correctly. Check the model.
Yeah, you may have to recreate the model in this new version because of the changes since the older one.
I tried loading the file again in Prepomax 2.0.0 and this is what I’m lookin at. The model is not getting loaded and the screen is blank.
.frd file with CalculiX results ? What FEM features does the model contain ?
I’m a fresher and a complete beginner. Could you please explain what you mean by FEM features?
Element types, constraints, interactions, step types and so on. Anything special, other than solid or shell elements in a regular static analysis with only boundary conditions and loads.
Can you open the file Models/Profile.pmx, run the analysis and open the results?
I am closing this bug report.
