is there an documentation on what variables can be used for equations in the results create field output?
Say if I wanted to report max(temp)-min(temp) or magnitude.surface_flux divided by surface_area of that same selection?
Thanks
Thanks
It’s not documented since it’s a new feature, not yet available in the stable version (only in dev versions).
You can find some tips (mostly regarding operators) here: A new developer/preview PrePoMax version v2.1.2 has been released - #3 by Gunnar
For the variables, those are just the available field/history outputs.
