So simply I can’t select seemingly random parts of models I import when assigning BC or Loads and I have no Idea why. I have updated graphics drivers but I’m using a AMD Ryzen 3 3200G with Vega 8 graphics. I create all my models in Solidworks and export as stepAP214 or Stl file format. In the models pictured I could only select the large section of the top surface. When performing the thin walled surface tutorial for whatever reason I can only select the lower portion of the model. I have used prepromax with all the out of the box settings, its weird
Did you try using a different version of PrePoMax?
yes, I tried multiple versions
I have not tried the integrated Vega 8 graphics card with PrePoMax. I would think that the graphics card/drivers are causing the problems.
Thats what I figured, I was hoping it was something easier to fix, guess its time for an upgrade
