BC seems applied to the wrong Selection
Not sure why my results are not as expected.
I’m still working on the set up but in the meantime I have found the following :
The two intermediate BC’s of the first and second step were imposed at the lip of the plate as show in the preview. After my results is not as expected I’m reviewing each BC again and found that when opening the BC details, the selected surface suddently changes its possition. Is that normal?. Now I’m not sure where the BC is aplied?¿
I haven’t clear anything to avoid altering the possible bug.
Now I can see that the problem is not a high stiffness.
Overall displacement doesn’t agree with the requested value of -150mm although the analysis reports as ended successfully.
EDITED: I have rebuild the whole model from zero and result is as shown in the picture. Still don’t know why BC was assigned to other area.
No, that is not supposed to happen. Thank you for the file. I will try to determine what is the problem.
I went through your model and think the problem is the Scale function. Now, I will try to find the best way to fix this for the future.
Thank you Matej.
May I ask how do you know that I scaled the mesh?
Does Prepomax .pmx records the commands that are executed?
Yes, all the commands can be seen using the Edit → View History menu.
Currently, it is only a read-only list.
I have reworked the code dealing with changes due to translation, scaling, and rotation. I hope it will not introduce some other problems. It will be released in the next version.
Thank you very much Matej.
