I would like to see a cross in the origin (0,0,0) . It would help to check if the step has properly been imported.
Thanks
Thanks
If you mean the rotation cross, that is not possible. Once you mesh the geometry, you can add a Reference point, but in the Geometry module, there is no feature to help you with that. You can only query existing points.
Thanks Mr. Matej.
Yes , I mean a second, maybe smaller, coordinate system without X,Y,Z letters in the 0,0,0.
If it is not possible maybe a big dot or reference point by default.
If not I will try the reference point
Another small detail. I have deactivated and activate again the scale widget and it now doesn’t show centered.
I will think about it. Usually, the position of the origin is not needed but in some cases (2D axisymmetric) it would be welcome.
In such cases it would be nice to have an option to enable the display of the symmetry axis (possibly in form of dashed line).
