Is it possible to add the selection of the coordinate system (see picture)?
Check this thread: Cylindrical coordinate system Rotational DOF's
There’s a pending discussion about the use of local coordinate systems for rotational degrees of freedom. We are not sure yet if it’s working properly in CalculiX.
Overlooked. I will check.
Thank you.
Forgot to mention: choosing Rectangular-CSys and not Cylindrical-CSys.
Thanks again.
The moments are actually nodal forces applied to the rotational degrees of freedom 4, 5 and 6 in CalculiX. That is why I did not add the coordinate system to the moment load. But now I think a better option would be to support it and warn the user to double check the results.
