Transform - extensions for point selection
I would really appreciate it, if the same selection options available for selecting the center of a coordinate system could be added to all the Transform point definitions:
Also it would be convenient, if the Transform features could be directly called up by right-clicking on a part. This is actually the only point under “model > part” which cannot be accessed directly via the right-click context menu:
I was under the impression that transform feature is not used a lot…
It’s really useful, I’ve also resorted to it several times.
If you refer to the context menu, maybe you are right and transform would be the least often used in the list.
But is there a chance to adopt the point definitions? This would be really great (and hopefully not too much effort) :slight_smile:
Thank you
Ok, I will try to change this behavior.
Thank you very much :blush:
