Hi all,
I’m new to PrePoMax and FEA in general. I’m struggling to produce a good analysis for my model, a balloon that is subject to an atmospheric pressure gradient. To model this, I’m using PrePoMax’s hydrostatic load, and setting it such that the magnitude is highest at the top of the balloon. However, when running analysis I’m noticing that the balloon seems to just tip to one side, rather than stretch in the z direction and expand circumferentially like I expected. I’m not sure if the problem is with my load, my model, or my boundary conditions, but I have tried quite a few different methods for analyzing this model and all have come up short.
I’ve tested hydrostatic loads on simple pressure vessels and PrePoMax seemed to show proper deformations, even when running non-linear analysis. But as soon as I add “seams” (the longitudinal components that run around the balloon, which are stiffer than the balloon itself), I run into issues.
The image below shows the finished analysis. When the analysis finishes, a message appears saying, “Some node coordinates in the result .frd file are different from the coordinates in the model mesh. Apply model mesh properties (part names, geometry…) to the result mesh?”
This is the base of the balloon–for some reason the seams are detached, even though I applied a tie constraint.
Hydrostatic loading parameters
Boundary conditions–I’m wondering if this is a possible culprit. I want the BC at the base of the balloon because that is where a payload would be attached.
Finally, here’s a previous analysis I did with similar hydrostatic loading parameters, but without the seam geometry. The BC was also the entire top dome of the vessel, not a few small surfaces like the model above.
I’ve been working on this for a while and I’m at a loss, so if anyone could help that would be great! Please let me know if there’s anything else I can provide to help you diagnose the issue, such as the .step file of my model or anything from PrePoMax. Thanks!
