First post here I have to say that I’m fairly new to PrePoMax/CalculiX but I love it! Thanks to the developpers for this free piece of software!
I’m currently testing PrePoMax by comparing analysis’ results with the Nastran In-CAD module for Autodesk Inventor. More specifically, I’m analysing the shell of an open-top water tank when full. To check the robustness of PrePoMax (v2.2.9-dev), I compared the results for the following analysis:
Full 3D solid analysis - Shell nodes of tank free
Partial (1 deg revolution) 3D solid analysis - cylindrical constraints
Full shell analysis - cylindrical constraints on shell
2D axisymmetric of tank of half cross-section. (On a side note, the draftsman did not generate the shell on the positive side of the radial axis, causing nonpositive Jacobian errors, I simply reversed the normal of the plane to solve the error, ignoring the “negative Z” warning.)
For the full shell model analysis, I get non-expected displacements results. I restricted the shell nodes in the revolution direction (theta or T) based on a cylindrical coordinate system but free in the R direction, and it seem the model reacts as if it’s a rectangular coordinate system. Am I doing something wrong? Is it a bug?
I have compute reaction force in one cone hydrostatically loaded with the new Dload. Compared to analitycal solution deviation is below 0.002%. Structured mesh and medium refinement level.
