Thank you for the quick response. I will try the preview option as well as the compound option. In this case would I still need to create tie constraint for the two parts?
In code-aster I use the liaison_mail which creates a contact between two meshes.
The difference is expected in this case. First-order finite elements can only account for constant stress through their thickness. And in your case, the side surfaces are loaded in bending, which causes a linear stress distribution through the surface thickness. Since you only have one (single) element through the surface thickness your model can not capture bending (linear change in stress through thickness). Second-order elements on the other hand can account for linear stress distribution through their thickness so a single second-order element through thickness is enough to capture bending.
Typically this would be modeled as surfaces (in midplane) and analysed using shell elements - have you tried this ? It would be interesting to compare.
I 100% agree with your comment regarding the PrepPoMax workflow. Not only is the workflow quicker, it is intuitive and practical. The user interface is way better than Code Aster.
