Saving simulation results
Every time I close a model and reopen it any request to look at the results fires up an error message which says that the run didn’t complete. I’ve selected the option which says to save results in the model file and played around with the home directory settings. I’m now out of ideas.
What version of PrePoMax are you using ? I assume that when you save and close, the analysis is completed (green symbol with checkmark) and the results can be opened ?
I have the Temp folder in the installation directory set as Work directory and “Save results in .pmx files” enabled and there are no issues.
Thanks for the super rapid response!! 2.2.4 dev but I also have the same problem with my other machine that is running 2.2.0 All analyses completed with a green tick, its set to save results in .pmx file and the temp folder is specified in the installation directory. I’ll try it on my laptop to see if that’s got the same problem..
How do you look at the results in the opened pmx file? Do you select the analysis again with a right click? You should just select the Results tab.
Poslano iz programa Outlook za iOS
I always feel so stupid in these situations.. I’ve been right clicking the analysis again. Didn’t check to see if the results were actually already loaded (spot the Abaqus user)… Thanks for your help.
