Opening a Previous Analysis File (within Windows Explorer) Does Not Load Anything
Hi all,
As the title says, I get nothing but the initial PrePoMax screen and no information is loaded.
I have this same issue on two different computers since version 2.1.8. Is it a bug ? Does it happen to anyone else ?
The only way to get around it is by starting a new PrePoMax session and from within PrePoMax "Opening’ the required file.
I added some command line parameters for controlling PrePoMax from cmd, and it seems the default behavior is not working anymore. I will check it.
*** Edit ***
I have fixed the problem, and it will be available in the next version.
Can you confirm the bug is fixed?
Hi @Matej,
Yes, it is. Thank you.
I am closing the bug report.
