HI, model is showing error i have made contact pair between both plates but still not running.
TEST1.pmx (181.3 KB)
You have to apply the boundary condition to the rigid body constraint’s reference node instead of the underlying face (since this results in an overconstraint):
However, the remaining two parts are not constrained which will lead to rigid body motions and non-convergence. You could tie the parts for now or apply sufficient minimum BCs to them (depending on what you want to model here).
Also, the mesh needs a significant refinement.
Just an example (I’m not sure about your goal): TEST1_mod.pmx (8.5 MB)
Thank you for the reply..
ill tell you, i am making the model, i have little confusion on modelling.
Ok, I’ll try to help with it.
