I would like to evaluate simple contact analysis.
But prepomax show below error.
Could you let me know how to set parameter ?
If the whole part is fixed, boundary condition and contact acting in the same region are causing overconstraint. Use rigid body constraint instead of fixed BC for that rigid part.
Dear FEAnalyst san,
Thank you very much!!!
If possible,Could you help chkeck my program ?
I don’t know why my problem can not run …
test.pmx (595.9 KB)
I was thinking about applying rigid body constraint to that small cube in the middle (if it’s supposed to be undeformable).
Dear FEAnalyst san,
Thank you very much for your kindly reply!!!
I changed my code…
But Analysis failed…
test.pmx (606.6 KB)
It will work if you apply the boundary condition to the reference point instead of applying it directly to the part.
Dear FEAnalyst san, ANYS san,
Thnak you very much!!!
My code run well!!
