Analysis not working for one load case
I am currently working on the FEA of a boom assembly of a crane. The modell consists of the boom, a sheet metal part at the end of the boom aswell as some bolts and pins that connect the parts. The boom is constrained by resting on a pin which has 5 fixed DOF’s (it can rotate along its axis). The rigid body rotation of the boom is restricted by a wire rope a the end of the boom (its a derrick crane), which I modeled using a rigid body constrain. Now the location of the point of the rigid body changes depending on the load case. I get good results for all load cases except for one, in which one of the connecting bolts just expands like it was spinning at a crazy RPM around its axis. This failure seems to depend on the location of the point of the rigid body and i cant figure out how to fix it. Pls help. (the Analysis were created using Prepomax ver 2.2.11 dev)
this is the result and setup of the not working Analysis
However if i change the point of the rigid body connection for troubleshooting or other load cases i get good results with the same model:
granted its a very steep angle but the following Analysis has also a steep angle and is working:
i have uploaded the 3 shown calculations to:
Can you share the file using a different hosting website ? With this one, I get an error:
Error
The URL doesn’t have the correct format.
The problem with that load case seems to be with contact not properly preventing the initial rigid body motions of the pin.
Ok, I can access it now. Apparently, automatic preview breaks links from this website. The < and > tags can prevent it: https://limewire.com/d/WUsrU#QeYlLDfJI0
ok good to know thank you
Connections look good, I checked them by replacing contact pairs with tie constraints (using the automatic search tool) and running a frequency analysis (always recommended when analyzing assemblies). The bolts also don’t have disconnected meshes or anything like that.
The results with this spurious deformation in the Auslegerhaelfte2vV150A90elastisch.pmx file are from t=0.0501953 s while the previous frame with correct results is from t=0.05 s. So it’s likely just a failed increment. I assume it stopped converging at that point ? It might be good to enable Nlgeom to get more realistic results (even just for debugging), but it will probably take quite some time to run. If it doesn’t converge, try replacing individual contacts with tied contacts or tie constraints to see where the issue is located (typically somewhere within the contact regions).
You could replace the rigid connection with a kinematic or distributed coupling by using the keywords editor.
I created a rigid body from the nodes of the bolt head and constrained the rotation about the z axis. After this the remaining two bolts of the connection showed the same behavior as the first one.
After restraining them aswell i got plausible results:
the von Mises stress in the fiber of the boom is about 20 MPa smaller than those i derived from Hand calculation. Maybe using a rigid body as a rope ist not the best approach.
I injected the following keywords:
The Analysis now stopped converging after a steptime of 0.1 s instead of 0.05. I had to kill it to work on something else but tomorrow i will run it again and see if the bolts show the same behavior.
I would try using tied contact or tie constraints for these bolts for now. If it still doesn’t converge, you may need to check other contacts as well.
I did that and I found that the problematic contact. Its the contact between the upper pin (the pin that connects the “wire rope” and the sheet metal part. Its enough to set only that contact as tied to get convergence.
How do I fix it now ? And how can a bad contact create weird behaviour in other contact regions ?
It would be good to identify the exact cause of non-convergence and locate the problematic nodes involved in that contact now. Perhaps just refining the mesh may help, or you may have to try different contact settings. Sometimes it’s even necessary to add soft springs to stabilize such problematic parts, but that’s the last resort.
