Sometimes the running calculation generates huge frd file (> 1GB). In case I want to check the newly converged steps, PrePoMax reloads everything again.
It would be nice if PrePoMax can do incremental loading for new steps only.
Hm, I am not sure of how to do that. I can not determine which parts of the .frd file were changed from the previous load and which parts to skip. This is not an easy task to solve in general. It might (somehow) work for a simple case but I am not confident it will work for all cases.
Probably it is easier to allow users to select steps to be loaded?
Yes, that is the only way. But I think this selection option should not be shown every time the user loads the results so an additional feature to load results by steps could be added.
