when a frd.-result File is read into PrePomax (v.1.3.2) directly, then wrong results are displayed. They also change when they are reselected - for example “DISP ALL” or “DISP U1/U2/U3” or “MISES”.
results within PMX
.frd-file read in
I uploaded a simple pmx-model and the result file calculated by PMX.
Try in v1.3.4. In the older version that you’ve mentioned (v1.3.2) I get some VTK error and indeed strange things happen - the results change each time I select a variable.
