I would like to do a simulation of a thin sheetmetal “skin”. So I created a very simple flat rectangular surface in SolidWorks and then saved as a STEP file. I am trying to import that STEP file into PrePoMax, and PrePoMax has issues with this every time I have tried importing the surface. Ultimately I would like to do a plane stress or plane strain simulation of this part.
What issues ? Are there any error messages ? Note that the surface has to lie on the XY plane for plane stress/strain analysis and you have to select the right type of the model.
Besides the fact that all points must have the z coordinate equal to 0, as FEAnalyst suggested for 2D analysis, the normal of the surface must be oriented in the positive z direction. The .step file should also only contain shell bodies.
Right, that’s also crucial. Fortunately, it can be easily corrected in PrePoMax using Geometry —> CAD Part —> Flip Face Normal. It’s often neccesary unless you ensure a proper face orientation in CAD software prior to export.
Thank you all for the replies. My structure was NOT in the XY plane. I actually have 2 intersecting surfaces…somewhat like an L-Bracket. I suppose that a plane stress or plane strain analysis will not work for this case because one of the surfaces will be out of plane.
