Import frd file
Is there a way to import only the frd file to post process?
I am using v 0.7.0.
Thanks.
/J.
Yes, you can open these files (File —> Open) for postprocessing.
I would advise you to switch to the newest version (1.3.2 currently). Yours is quite outdated. Unless you want to avoid issues with backward compatibility, of course.
I appreciate your prompt response I will try. The reason I am not using the latest version is because the import buttons were greyed out and could not import my step. This did not happen with the version 0.7.
That’s likely because you have to create a new model first (File —> New) before importing geometry/mesh.
