Hide result part
Good Day,
I’ve tried to make deck strength analysis for a barge where Container loaded trailer is moving on top of deck. For the sake of simplicity, i only analyse 1 tire which has maximum force.
after running the analysis i notice there’s a message as shown below
**** Exceptions ****
12/10/25 15:13:58 Hide result parts: The given key ‘Solid_part-11’ was not present in the dictionary
What could be the cause of this problem here ? i’ve concern that the result shown may be not accurate enough because a part is hide by the system. Please advice
The information only states that some part is not found. Did you apply the Run postprocessing commands in the pop-up window after opening the results? That might be a problem.
No, but when i tried to run the analysis using new version (Prepomax 2.4.2) & there’s no “Hide Result” message. May be it’s a bug in the system
So, can I close this topic?
