would be useful to be able to select and hide elements when viewing the results without having to define sets and rerun
Currently, only parts can be used to hide/show elements. How do sets and re-running the analysis help you now?
Promote set to part and re-run, I think
Yes, it’s even mentioned in the documentation:
Convert to Part - part created this way can be deleted to remove selected elements from the model
Can this be done after the analysis is completed?
I didn’t see a way to do this on the results unless the parts were in the model initially.
If you convert a set to a part, you can rerun the analysis so that it’s solved with that part included.
No, but adding it might be a good and simple solution.
