Error Importing *DLOAD from .inp File
I’m getting an error when importing a CalculiX .inp file containing a *DLOAD card .
I am using Prepomax 2.3.9 dev
The error is:
Error: Failed to import distributed load: *Dload
ELEM_FACE_Y_MIN, EDNOR1, -1
The relevant section of the .inp file is:
*DLOAD
The core issue seems to be with the PrePoMax importer. Here’s why:
  1. An analysis created manually inside PrePoMax with this user-defined load works perfectly.
  2. However, if I export that working model to an .inp file and then try to re-import it, I get the exact same error.
Is there a recommended syntax workaround for the .inp file to make it importable?
This is a link to a zip file with the script-generated .inp, the working .pmx, and the exported-from-PrePoMax .inp for testing.
Thanks for any help.
Check this thread: Import DLOAD error - #3 by Cean
Here EDNOR is a label used by normal shell edge load. Apparently, it’s not yet supported by the .inp file importer and the load has to be redefined in PrePoMax after import.
Ok, noted, thanks for letting me know
