Can anybody tell me how to open it in Prepomax :
"failed nodes are stored in file
ha064_OBL2_WarnNodeMissTiedContact.nam
This file can be loaded into
an active cgx-session by typing
read ha064_OBL2_WarnNodeMissTiedContact.nam inp "
Why not trying to load those files as includes on your main input file?
I would also like to know the answer to the original post. Is there any issue with the read function as the node set fails to be created? If I File/Import the GUI seems to behave properly, i.e. no errors. I then get the following in the dialog box.
06/17/24 16:56:33 Import file: D:\FEA\Analysis-1_WarnNodeMissTiedContact.inp
06/17/24 16:56:33 Reading keyword line: *NSET,NSET=WarnNodeMissTiedContact
But no new node set gets created. The input file looks like this: (Which seems reasonable.)
3975955
3118673
3118674
3118675
3118676
3118677
Thoughts?
thanks!
This file should automatically be loaded in PrePoMax when clicking the Results button in the Monitor window. You can find the nodes in the Results Node Sets:
thanks for help this info is very usefull
