Import DLOAD error
Ver2.0.0
I got this error :
 Error: Failed to import distributed load: *DLOAD
 2, P1, -2.858039
 3, P1, -2.266650
What’s wrong with this DLOAD ?
Regards,
Cean
The .inp file importer is not yet fully developed and doesn’t support as many features as the exporter (and PrePoMax itself) supports. In this particular case, the limitation is that only *DLOAD keywords defining gravity loads can be imported. Usually the best way is to import just the mesh and reassign the other features (like loads) in PrePoMax.
Thank you very much. I am just want to check load.
Better say not supported yet than error.
