I would like to propose a feature which is hopefully not too complex to introduce and will automate some laborious tasks.
Take for example a case where there are many bolt holes and we need to create Rigid Bodies to replace the bolts.
Currently we have to individually select the Node Sets, then individually create the associated Reference Points, then individually create the associated Rigid Bodies. The task of individually doing this is tolerable if there are just a couple of bolt holes, but any model that has more than half a dozen or so bolts does become rather tedious.
Some commercial software have an option where the software can automatically create multiple instances by selecting filters such as “similar size” or “same location on x or y or z axis”.
In PrePoMax case this could apply to automatically detect and creat Node Sets or Reference Points or Rigid Bodies, using these same filters. Obviously PrePoMax would need to automatically assign sequential reference numbers to each instance it creates. In this way one could create Rigid Body instances in large models within a couple of minutes.
Similarly this could apply to not only creating Rigid Bodies for bolt holes, but also other scenarios such as applying BCs or Loads, and probably others too, which I have not mentioned.
