I’m transferring from another FEA system. I’m finding the basic workflow in PrePoMax less than obvious.
I want to assign the same material to multiple parts of the imported model - do I really have to create a section in turn for each part and separately assign material to each section? Is there some option to speed this up?
You can create one section with a selected material and apply it to multiple parts - just hold LMB and drag the selection box or select multiple entities (e.g. parts) while holding SHIFT.
Number of parts - started off at about 120, but I’ve merged a lot of items to try to make things more manageable, and have removed one particularly complex one altogether. Now 47 parts. Initially I was running out of system memory, now still getting some crashes whilst trying to set surfaces.
Nodes - probably far more than needed. I just used defaults for meshing.
Guess I need to re-mesh with larger mesh size? My previous system spoiled me by optimising the mesh automatically (which was great, but it’s now an old unsupported system and doesn’t always manage to successfully mesh - hence trying PPM).
Yes, this mesh is huge. You should start with as coarse mesh as still reasonable in your case and refine as needed. CalculiX is quite sensitive to large meshes and it’s likely that it won’t run this analysis (you should use Pardiso solver right away to reduce that risk).
Assuming that you have the geometry imported, just go back to the first tab in the tree, change the mesh settings and remesh. Most analysis features should be reapplied properly.
Unfortunately not (though I may end up chopping it in half - even though that will introduce some errors).
Sorry - that is beyond my current experience level. What is the benefit of using hex elements in this case?
Not really. It’s a complex 3D assembly (already extracted from a much larger assembly). Simple calculations suggest bolting may be tight on design factor - so wanting to run FEA to identify any higher stress locations that may not have been noticed so far.
