When creating a Reference Point and choosing either Circle Center by 3 Points or Between 2 Points, there is no option to select the required nodes/points. This functionality is expected, as in other operations such as Part → Transform → Rotate, where selecting nodes/points is possible.
Steps to Reproduce:
Go to Reference Point creation.
Select Circle Center by 3 Points or Between 2 Points.
Attempt to select nodes/points.
Expected Result:
The tool should allow selecting nodes/points to define the reference point, similar to other operations (e.g., Transform → Rotate).
Actual Result:
No option is available to select nodes/points.
Environment:
Win 11, PPM 2.3.9 dev
Thank you very much for dedicating your time to the development and improvement of this great software. I really appreciate your efforts and the value it brings to its users.
