I am running 2.4.3 dev with merged shell models and find it impossible to select points to define an axis to rotate the part. If I randomly click enough it might select something but isn’t behaving as expected. I can select points in the same model without issues elsewhere in the program, (such as query mode)
Thanks for looking into it. I will check as I open different models but I think it has been an issue for many of them. You might test a model with multiple compound parts (and try to move more than one at the same time)
