I understand that pyramid-elements are in an experimental state now and not all prepomax functionalities are fully tested with them yet, however i want to point out some observations i made (perhaps more will follow):
The Transform options “copy and translate/rotate” does not work for parts with pyramids (they will be listed as new part in the model tab but are invisible in the graphic window).
Most of the query items in the results tab does not work properly.
Edit:
BCs applied to region type “surface name” leads to an error (no problem with “selection” and “node set name”)
Thanks, all mentioned bugs are fixed now for linear pyramids. But there is still a little bug i figuered out now:
When creating a rigid body constraint with region type “surface name”, the ayalysis runs but gives zero values for all outputs. When i switch from surface name to selection, results are fine:
But now in v2.0.6 (was not a problem in v2.0.5), nothing works anymore when using 2nd order pyramids. No matter which BCs i applied, it always gives the error:
Looks good, i could only find minor query problems in the results tab for 2nd order pyramids (queries can’t be placed or will not be highlighted):
Vertex/Node
Edge
Surface
Distance/Angle/Circle
But the strange thing is, this only doesn’t work for results loaded in the .pmx file after analysis. When i open the .frd file separate, all queries work.
Also a problem with section view - “select point” of 2nd order pyramids doesn’t work:
Edit
Sorry I have to correct myself again. Both phenomena described above are more specific and not generally the case. It’s somehow related having pyramid elements as separate parts i guess. The animation shows it better than trying to describe it.
