Using *TRANSFORM for any node in the model
Hello everyone!
I couldn’t find a way to directly change the coordinate system for a specific group of nodes not belonging to boundary conditions (reference post can be found here).
Because of this, I would like to request the ability to change the local coordinates of any node (directly or per node set) in the model, it’s very useful when you want to read results in a specific coordinate system.
Right now, a workaround is possible: add a dummy load associated with the desired CSYS with negligible values to the nodes you want to apply the *TRANSFORM card.
Thank you,
Lucas.
