Currently only some loads allow user defined coordinate systems, like surface traction.
Thanks,
Thanks,
User-defined coordinate systems internally rely on the CalculiX’s *TRANSFORM keyword which changes the coordinate systems of the selected nodes from global to local and thus it only affects nodal forces and constrains (BCs, MPCs). For other kinds of loads, it would have to be realized differently (in the case of gravity, it would require converting the input to gravity vector’s components (now it needs to be done manually if you want to apply gravity not aligned with the global axes).
