Hello everyone!
There is a known limitation in CalculiX output request when using Global=No and Totals=Yes for nodal values, because the total force is not calculated in the local coordinate system even if a *TRANSFORM card is applied. The reference post can be found here.
I would like to request a post-processing tool that could convert the total forces to some coordinate system to address this limitation in the solver. If possible, the tool could automatically select the CSYS used in the nodes (or node set) selected for the history output.
A workaround is possible by extracting the *.dat results to an Excel file and sum the individual forces for each node.
Best regards,
Lucas.
