Unusual results with tie constraint
Hello
I am doing a static analysis where I apply gravity load on my assembly. The problem I have encountered is with tie constraints.
As you can see from the picture that the marked parts are tied with eachother with sufficient search distance to form tie constraint
Still, when I look at the displacement contors, the tied regions look like to have relative displacement between each other.
It does not make sense to me. Shouldn’t the tied regions show same displacment contors ?
Here is the file
can anyone please help me identify the error
Thank you in advance
You can easily check if tie constraints work properly by running a frequency analysis. If anything is disconnected, it will be visible in low frequency modes.
Thank you for the suggestion.
My first mode starts at 50.65 Hz. I will not see any rigid body motion as my side plates are properly connected to the bottom frame. I still have the doubt that something is wrong as I see the maximum deformation in the plate where I suspect that tied constrain is not working there properly
What if you animate the mode shapes ? The displacement values in frequency analyses are unphysical but deformed mode shapes can be very helpful.
You could also check the warning messages about nodes involved in tie constraints.
Your constraint is not working. If you use Automatic scaling of the results, you will be able to see it.
In CalculiX, one surface must not be a master surface (red) in a tied constraint more than once. You have constraints part-81_to_part-49 and part-81_to_part-41, which violate this principle. You should merge such constraints into one (select both, right click, merge).
I couldn’t check the file yesterday but right, that’s also why there’s a bunch of warning messages such as:
 *WARNING in gentiedmpc:
          DOF            1  of node       168558  is not active;
          no tied constraint is generated
          DOF            2  of node       168558  is not active;
          DOF            3  of node       168558  is not active;
Thank you so much. I really didn’t know this. I will try to correct it
I tried your suggestion @Matej, also thank you @FEAnalyst. My problem has been solved
