Dear Forum,
As you may have seen over the past couple of days, I have been trying to complete simulations of several very geometrically primitive aircraft wings.
As I try to simplify my CAD geometry, the behavior of the simulation results becomes more and more unexpected.
In the screenshot below, I split the aircraft wing into upper and lower skins. The wing base is fixed, .1N upward load at wing tip, and the 2 spars are constrained to the lower wing surface using TIE constraints. I have tried applying the TIE connection between parts AND between surface and edge. I get the same results.
TIA,
–Neal
Please try running a frequency analysis. This should reveal issues with connections between the parts/meshes. It might be a matter of a too coarse mesh (like with contact here: Assistance with Specifying Deflection Behaviour - #4 by FEAnalyst) or too low tolerance in the tie constraint definition. But it’s hard to say without checking the model.
Thank you. I will go ahead and do this.
Dear Forum,
So I just completed a frequency analysis and this the the result in Mode #1.
Is this result telling me that the left rib showing all of the deflection is NOT connected to the lower wing skin surface?
TIA,
–Neal
Yes, you can animate this mode shape to see how it deforms individually. As I said, refine the mesh and adjust the tolerance.
