I’m running into this error when trying to assign loads. I’ve tried reopening the file but then I get another error: “The parameters could not be evaluated. Check the parameter equations” and no 3D displayed.
I’ve looked at this topic but it didn’t help solve my case. I’ve also tried relocating the file to desktop and still no luck.
Hope it’s not corrupted as I’ve spent some time assigning materials and creating sections.
Yes. It’s my personal computer so I’m admin. Have put the programme in Documents as that what some people here suggested. Have also added it as an exception in McAfee.
Don’t have the command history. Will work off from the Desktop this time.
Something was incorrectly saved. Can you describe as well as possible your procedure outside PrePoMax and the versions of PrePoMax you were using? Did you create everything in the same version (there is a bug that I fail to find).
To get the model working, you can try running the command history again. If you still have the .step file in the same folder, you can rerun all PrePoMax commands using: Edit → Regenerate History. If the .step file is in another folder, use Edit → Regenerate History Using Other Files and select the file.
