Section View - do not cut elements
Hi devs,
I would like to request following feature:
To verify and quickly visualize internal elements, I really like the possibility in Ansys Mechanical to show the “full” elements on the section view plane.
In PPM you’ll get:
In Ansys you can toggle the elements (green circle) which results in following view instead of a plane cut.
Best,
Stoli
I second the request…In fact I proposed the same thing in 2022 :slight_smile:
To do that In Abaqus, we just use Display Groups and hide the box-selected elements. Would be great to have an option to hide selected elements (in addition to parts) in PrePoMax: Hide elements when viewing results
Indeed, to hide box selected elements would also do the trick - probably with less effort for the implementation.
Best,
Stoli
I guess it could be based on element set creation and use the same selection methods (individual or box selection). Even allowing hiding elements by elsets without converting them to parts should be good enough.
@Matej thank you!
Topic can be closed :slight_smile:
I am closing the topic. Did you also try the hatched cross-sections?
