Can you implement such feature as rigid link (for example between parts )
You can use Reference Point and Constraint Rigid to connect multiple components. In this case, the reference point is not needed but must be created to complete the creation of the Rigid connection.
thank you
You have probably fastest answer when compare to comercial software
best regards
Rigid link.pmx (4.6 MB)
probably another feature in hinged connection between part can be useful, maybe using distributing coupling keywords with dcoup3d and beam element.
