When a model contains several analyses, it’s possible in the Results tab to switch between the different results set by using the drop-down menu at the top of the screen. That’s a great feature!
The thing is, when loading other results, the plotted field output gets reset to DISP.ALL (or likely the first field in the list). It would be great if the selected field could be remembered, so that when switching between results, one could see the differences between different analyses better and more explicitly (for example when looking at von Mises Stresses or displacements in a specific direction)
