I wanted to test the new compression only feature, for this i created enclosed file with two models:
- two parts with contact (plate + bolt) and
- plate with compression only.
The simulation runs successful but can’t be opened in prepomax - Error:
the frd file is okay and can be opened in ccx:
After deleting the 2nd model, the results can be opened again, but before after starting the calculation, the following warning still occurs:
So each model works fine, but it seems a frd file containing results with “compression only” + “contact” can’t be opened in prepomax.
pmx_file.zip (142.5 KB)
