Congratulations for your great work!!
I wanted to report a small problem. Well, not bug at all, but a small dysfunction for me.
I’m assigning a surface to a name say “ALPHA”. If I want to add one more surface to it I can do it. But if the surface is getting unassigned, say when I want more dense meshing so I delete it from the “FE model” section, the name ALPHA remains in red color with no surfaces assigned to it. If I recreate the mesh from the geometry, there is no way to assign a new surface to the existing name ALPHA. I have to delete it and create the same name from the beginning.
If there is a way to fix this problem in a future version, I would be grateful.
