Shell surface labels incorrect for Abaqus
I’ve noticed that surfaces defined on shells in PrePoMax v2.3.7 dev use naming not compliant with Abaqus even when it’s selected as a solver. For example, the following error message may appear:
 ***ERROR: UNDERLYING ELEMENT X CAN ONLY HAVE SPOS,SNEG,E1,E2,E3,E4 OR EDGE AS
           A FACE IDENTIFIER
Here’s the file:
Shell edge naming for abq.pmx (32.3 KB)
Face numbering in Abaqus:
Distributed loads (such as pressure) also need proper face numbers for labels like Px.
Also, I get this error when trying to open Abaqus results in PrePoMax:
I will look into the shell surface definitions. And opening of the results is currently not supported, but I would need to remove the error and show a warning message.
Or maybe disable (gray out) the Results button for now when the solver is set to Abaqus. But a (tooltip) warning would still be helpful.
I tested the attached file, and now the Abaqus analysis runs.
