Good day,
Is PPM a 32 bit or 64 Bit program ?
Are there physical limitations to the amount of RAM it can access and (by association) the number of nodes (with 6 DOFs) it can handle ?
Regards
Good day,
Regards
64Bit
I can confirm that PrePoMax is officially released only as 64bit application.
Noted; and thank you.
So, does PPM (with Calculix) have any practical RAM access limitations when analyzing ‘large’ models ?..i.e. can it access 128GB (or even 256GB) of RAM ?
RAM is much more important for the CalucliX solver. But for PrePoMax there is no limitation on RAM.
