Plastic Deformation
Dear colleagues, do you know how can I simulate a plastic deformation of a material, where I apply a compression force and them remove this force at the end of the simulation, to have only the plastic deformation?
Thank you in advance
Define two static steps and deactivate/remove the load in the second step. Or, if you want to remove it in a different way than linearly, use the amplitude feature.
