Plastic Data points plot curve
When entering a strain value under the Plastic tab and attempting to plot the curve, the graph is displayed incorrectly.
This issue did not occur in previous versions of PrePoMax. Has something to do with the temp axis:
Aha. After some tests, you selected CTRL+A to select all cells. Selecting with a mouse works normally for me.
nope when selecting with mouse it also happens (just 1+2)
Same in 2.3.0:
For me, it works by selecting with the mouse. However, there is a problem, and I will try to solve it.
thanks Matej for help :slight_smile:
Does it work in the new version?
Hello Matej,
i did checked and it worked now again, thanks for the fast update :slight_smile:
2.4.3 dev:
