Maybe i did not found the feature yet, but i would like to do a Graphplot of the mises stress values along a kurve or line.
I saw some examples online where the Calculix CGX can do it somehow.
Wonder if there is a workflow in PrePoMax present for this.
For now i think the only way might be to output the desired elements with history output and do mises calculation “by hand”
There’s no such feature in PrePoMax yet but ParaView and FreeCAD FEM have it.
You can create a history output From Field Output and select an existing edge for the data. Then, set Node coordinates to Deformed or Undeformed. Then, you can copy and paste the resulting data and coordinates to Excel, where such a diagram can be created.
Dear @Matej thank you for your comment and the work you have done so far.
I see so much potential in this platform.
I am sorry but i can not follow your instructions.
i understand the nodeselections via history outputs, but how can i select for these nodes a stress output. can you please show me the workflow with a few screenshots ?
I think this feature is absolutely necessary. Almost every post-processing needs a graph of element results.
