Matej,
a feature that could be useful in defining node sets in the possibility to select the nodes based on a list in an external file.
Thx
Vittorio
I think this would mean that the mesh is prepared outside PrePoMax?
Yes, the most frequent case is the import of an existing model from another program that is without the geometric entities and/or custom set definition based on loads or boundary conditions.
Tkh
So, the node set could be created or added to the original inp file when the file is imported. If later a node-set is needed (when the model is half prepared), the node-set can be added to the originally imported inp file, and the Edit-Regenerate command can be used.
It is cumbersome, but I think it should work.
