No result file, and no open
The calculation finished normally, but the result wasn’t saved.
Check in the working folder /Temp if there is .frd file. Do you have default field outputs set?
You can always try submitting the analysis externally: Using standalone CalculiX
But most importantly, check if the .frd file can be imported to PrePoMax or opened using GraphiX (described in the thread linked above).
