I would like to apply a uniform pressure and a torque to the same surface, in red in picture. So, I defined a reference point, and linked to that surface.
Then, on the same static step, I defined the uniform pressure and the torque on ‘‘Load’’. But, when I run the software, the uniform pressure isn’t displayed on the results, like if it wasn’t applied.
To simulate torque you have to apply a rigid body constraint to the selected surface. This makes it rigid and thus the pressure load won’t be able to act properly. What does this model represent and why is that surface supposed to be loaded with torque and pressure at the same time ?
Do you mean superposition ? How is this shaft fixed ? Maybe you could apply the load in two subsequent steps and transfer the torque differently so that the middle surface is not made rigid.
Yes, I meant superposition effect, I’m sorry. The shaft is fixed on both ends. How can I use the subsequent steps properly? How two steps affect the results?
